  • jonok 297 posts 658 karma points
    Apr 20, 2019 @ 21:22
    jonok
    Surface controller - accessing node content and properties
    I am creating a surface controller that needs to retrieve nodes from a nested content property, but I'm not sure of the correct way to access the property.
    I am trying to do something like this:
    var block = CurrentPage.Value<IEnumerable<IPublishedElement>>("blocks").Where("Visible").Skip(currentCount).Take(1);
    I have tried lots of variations but can't find any examples that work - any help would be greatly appreciated. Instead of using 'CurrentPage' I could load the current page node using an ID if that helps, but I'm not sure how to do that in a surface controller either. I have tried this:
    IPublishedContent content = Umbraco.Content(1234);
    but then I get the error "The type or namespace name 'IPublishedContent' could not be found".
    Apr 21, 2019 @ 08:46
    Alex Skrypnyk
    Hi Jonok
    What Umbraco version are you using? Can you show all the code you have?
    Alex
    Apr 21, 2019 @ 21:05
    jonok
    Hi Alex, I'm using version 8.0.1, here is the surface controller code. I've got lots of 'using' statements as I can't seem to use the 'IPublishedContent' type, and was trying a few things.
        using System;
        using System.Web;
        using System.Web.Mvc;
        using System.Net;
        using Umbraco;
        using Umbraco.Core;
        using Umbraco.Core.Models;
        using Umbraco.Core.Services;
        using Umbraco.Web;
        using Umbraco.Web.Mvc;
        using Umbraco.Web.Models;
        namespace MyNamespace.Controllers
            public class MoreBlocksController : Umbraco.Web.Mvc.SurfaceController
                public ActionResult LoadMoreBlocks(int currentCount,  int moreCount)
                    //get nested content property node from current page
                    var block = CurrentPage.Value<IEnumerable<IPublishedContent>>("blocks").Where("Visible").Skip(currentCount).Take(1);
                     //or try to get it from content?? doesn't work either
                    block = content.Value<IEnumerable<IPublishedContent>>("blocks").Where("Visible").Skip(currentCount).Take(1);
                    return PartialView("Blocks/Image List Block", block, new ViewDataDictionary(this.ViewData) {
                        { "blockCount", moreCount }
  • Thomas Kassos 54 posts 265 karma points
    Apr 21, 2019 @ 23:37
    Thomas Kassos
    Hi jonok, I saw you question and I made an example. I manage to get the property values from textstring in a nested content. I don't know how this will work with media/member/content pickers. Hope you can make a start from that.
    If someone has a better solution would be nice to share.
    namespace Umbraco_8_tests.Controllers
        public class TestingController : SurfaceController
            public const string PARTIAL_VIEW_FOLDER = "~/Views/Partials/";
        public ActionResult TestSurfaceController()
            return PartialView(PARTIAL_VIEW_FOLDER + "_TestSurfaceController.cshtml");
        [HttpPost]
        public ActionResult testingSC()
            dynamic nestedContent = Umbraco.Content(CurrentPage.Id).GetProperty("nc").GetValue();
            foreach (var item in nestedContent)
                System.Reflection.PropertyInfo pi = item.GetType().GetProperty("TextNC");
                string itemValue = (string)(pi.GetValue(item, null));
            return View();
    Apr 22, 2019 @ 01:03
    jonok
    Hi Thomas, Thanks for that, it's definitely helping me understand surface controllers - however I am trying to get an Umbraco node to pass to the PartialView as the model. I'm hoping there is some way to access Umbraco nodes (eg. IPublishedContent) in a surface controller?
    Apr 22, 2019 @ 09:32
    Alex Skrypnyk
    Hi Thomas,
    First of all - do not use "dynamic" type. Everything is strongly typed now.
    This line not needed also -
    You can always know which type to expect from the property.
    Alex
    Apr 22, 2019 @ 10:20
    Thomas Kassos
    Hi Alex, I used dynamic because I had an issue with this
            var nestedContent = Umbraco.Content(CurrentPage.Id).Value<IEnumerable<IPublishedContent>>("nc");
    it was always null, any thoughts why?
    Cheers
    Apr 22, 2019 @ 11:22
    Alex Skrypnyk
    Use this :
    var nestedContent = Umbraco.Content(Umbraco.AssignedContentItem.Id).Value<IEnumerable<IPublishedContent>>("nc");
    Apr 22, 2019 @ 11:31
    Thomas Kassos
    Didn't work..
    Apr 22, 2019 @ 11:55
    Alex Skrypnyk
    this one works for me:
                string itemValue = item.Value<string>("TextNC");
            return View();
    Apr 22, 2019 @ 12:06
    Thomas Kassos
    Didn't work either
    Its not that I will have an error from this:
    or this:
    the issue is that returns always null
    and those (wrong ways),return the 2 items I want to get. but as an object, no as IPublishedContent
    var nestedContentV2 = Umbraco.Content(CurrentPage.Id).Value("nc");
    var nestedContentV3 = Umbraco.Content(CurrentPage.Id).GetProperty("nc").GetValue();
    Apr 22, 2019 @ 02:40
    Thomas Kassos
    If I understand right, you need a form to post to the controller the pageId so you can access any node no matter the page you are.
    Anyway generally speaking you can access the nodes as IPublishedContent on a Surface controller
    All those are working
            var homePage = Umbraco.Content(CurrentPage.Id);
            var textString = homePage.Value("text");
            var rte = homePage.Value("rte");
            var image = homePage.Value<IPublishedContent>("image").Url;
    I couldn't get this one to work
            var nestedContent= homePage.Value<IEnumerable<IPublishedContent>>("nestedContent");
    Apr 22, 2019 @ 21:07
    Alex Skrypnyk
    Hi Thomas
    How many items are created in the nested content property? Are there many or just one?
    If your Nested Content property editor is configured in single item mode, then the value converter will automatically know this and return a single IPublishedElement entity rather than an IEnumerable
    Alex
    Apr 22, 2019 @ 23:51
    jonok
    Hi Thomas, I can't get anything with IPublishedContent to work. I get the following error: "The type or namespace name 'IPublishedContent' could not be found".
    Do I need to declare anything at the top of the controller file to allow me to use IPublishedContent?
    Apr 22, 2019 @ 23:54
    Thomas Kassos
    101
    Hi Jonok, I had those, give it a try
    using Umbraco.Web;
    using Umbraco.Core.Models.PublishedContent;
    Apr 23, 2019 @ 00:09
    jonok
    Thanks Thomas - the Umbraco.Core.Models.PublishedContent was the one I was missing. So now when I try the following code:
    var page = Umbraco.Content(1174);
    var block = page.Value<IEnumerable<IPublishedElement>>("blocks").Take(1);
    ...I get this error " 'IEnumerable
    I can use this code inline within a view and it works fine, but I'm not sure why the Take(1) isn't possible in the surface controller?
    Apr 23, 2019 @ 00:15
    Thomas Kassos
    Well probably its U8 issue.
    Your problem should be the same with mine, IEnumerable IPublishedElement doesn't work (take(1) shouldn't be a problem )
    I have use surface controllers in U7 many times and I had no issue.
    You can try George Phillipson solution for now.
    Apr 23, 2019 @ 00:20
    Thomas Kassos
    Hi Alex, there are two items
    In this comment I made earlier you can see clearly the issue I described to you
    https://our.umbraco.com/forum/umbraco-8/96911-surface-controller-accessing-node-content-and-properties#comment-306308
    Cheers, Thomas
    Apr 23, 2019 @ 02:34
    jonok
    Hi Thomas, I can't believe it was this simple but I was missing the 'using System.Linq;' declaration at the top of my surface controller. So to fix my original issue, it turns out all I needed was these 2 lines:
    using System.Linq;
    Thanks for your help.
    Apr 23, 2019 @ 16:09
    Alex Skrypnyk
    We are glad that it's solved.
  • George Phillipson 108 posts 288 karma points
    Apr 22, 2019 @ 09:59
    George Phillipson
    I have been testing out V8 and here is an example of how I get the nested content to work.
    1) I'm using modelbuilder so in my view I have:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<Web.Model.Helper.Contact>
    2) I'm not sure whether you are posting the page to the SurfaceController or whether it's on pageload, if posting add the following to a hidden field.
    var id = Model.NestedTest.ToList();
    3) SufaceController
    public ActionResult NestedContent(IEnumerable<IPublishedElement> id)
    var publishedElements = id.ToList();
                var components = publishedElements.ToList();
                    foreach (var data in components)
                        var testOuter = data.Value<HtmlString>("bodyText");
                        if (data.ContentType.Alias == "nestedThreeDoctype")
                            foreach (var item in data.Value<IEnumerable<IPublishedElement>>("nCThree"))
                                var testInner = item.Value<IHtmlString>("bodyText");
                return null;
    I have attached an image to show my backoffice layout, this is just me messing around with V8 but it should give you an idea of how to do what you want
