  • Tizer 170 posts 201 karma points
    Jul 10, 2012 @ 06:10
    Tizer
    Contour on Umbraco 4.0.3
    Hi - I submitted a support ticket, but I am not sure if it went through.
    Can I use Contour with:
    Umbraco 4.0.3
    .NET Framework 3.0
    MS SQL 2005
    MS Visual Studio 2005
    I have seen that there are packages still availble, but are they supported?
    Also can I buy a license and use it on a live site and a test site?
    Jul 11, 2012 @ 02:31
    Tizer
    OK - I don't think my ticket went through (and from memory there wasn't a field for an email)
    Is it safe and secure to use old packages for old versions of umbraco?
    Jul 11, 2012 @ 04:32
    Tom Fulton
    Hi Tizer,
    Contour definitely works on 4.0.3 (I have a site running it), but I'm sure you'll need a certain version and support for it probably stopped at some point.
    Per this thread 1.1.9 should work, but I would suggest you take a backup first and try on a dev copy, or confirm with Tim/Umbraco first.  Here are some other threads regarding 4.0.3 and another one explaining a potential licensing issue + fix.
    Regarding your license query, yes, when you purchase a license you can specify both a production and a development domain.
    -Tom
    Jul 11, 2012 @ 10:42
    Tizer
    Wow - great reply Tom - I'll start reading through these now :)
    Great Google search tip also.... I didn't know about that one.
