I would like to build some forms that can be submitted manually through the normal process, but also can be posted to "behind the scenes" from JavaScript found on another page. Trouble is that the editor controls generated by Contour have names generated by ASP.NET à la "ctl00$ctl00$ctl00$ctl00$ctl00$ctl00$ContentPlaceHolderDefault$pageMainContent$pageMainContent$pageMainContent$ctl00$RenderForm_8$rpFieldsets$ctl00$rpFields$ctl00$f177d7e4_43ac_47bb_8a7d_e2f6f84f38be", which can't be trusted to remain constant. So I can't just hard-code those names into my external JavaScript.
The only way that ocurred to me to get around this was to manually create field types like ExplicitlyNamedTextField, ExplicitlyNamedCheckBoxList, etc, each one of which would explicitly set it's editor control's ClientID. But this would involve a lot of repetitive work and would have to be manually repeated every time a different field type needs to be created.
D'oh... it looks like I made the cardinal error of getting into custom implementation work without looking for the "lazy way" first... Cultiv RestContour appears to be exactly what I was looking for.
Explicitly named fields for POSTing from elsewhere
Hello Umbraconauts,
see also: defining an id on input fields
Can anyone think of a better way to do this?
Evan Harper
