  • Jonas Eriksson 930 posts 1825 karma points
    Apr 02, 2014 @ 16:03
    Jonas Eriksson
    Add info text to form
    We need to be able to add text to forms. A good way would be with a "label" or "free text" type.
    Today we use the section header. But even though that one can hold quite a bit of text, it's not very elegant.
    A bonus would be to be able to add rich text with some html.
    Apr 02, 2014 @ 17:11
    Dennis Aaen
    Hi Jonas,
    Here is a post that have the same subject.
    http://our.umbraco.org/forum/umbraco-pro/contour/49501-Adding-text-to-a-Contour-form
    Maybe you could try using the suggestion that Donald posted.
    Hope this helps,
    /Dennis
    Apr 02, 2014 @ 17:28
    Jonas Eriksson
    Ah, Contour Contrib, and it seems to be updated for u7. Will have a look. Thanks :)
    Apr 02, 2014 @ 17:42
    Jonas Eriksson
    I had a look - and the good news is the Label pops up and works. The bad news is that it's not very pretty inside the designer. I guess I'll need to create a custom field. Something like a read only multitextbox.
