Hi guys,
I can't seem to be able to set a "Send XSLT transformed email" when a Contour form is submitted.
I've tried various XSLT files, and even the sample file that is there as a helper, but with no luck.
Contour's standard "Send email" works great, but this seems to simply do nothing.
I'm wondering if there's some manual step I'm unaware of?
Also, I'm using Umbraco ver 4.0.3 and Contour ver 1.0.10 in case that helps.
Appreciate any help.
Anything?
Could someone clarify that I'm at least doing the right thing?
Installed Contour from package repository.
Create form > create on submit workflow > type: Send xslt transformed Email > addess, subject, select local file (lets say the sample file) > Add.
Forms looks and feel fine, no errors pop up, I get the Thank you after submit - just not the email.
I have to same problem :-( Anybody got any solution?
I just had the same issue, but it was related to errors in the example XSLT template file. Try using the example template here: http://our.umbraco.org/forum/umbraco-pro/contour/18103-Send-xslt-transformed-email-Here-is-my-xslt-email-template. ; Worked for me, and is a good foundation to build from.
Hi Dan,
A trying to achive the same thing but seems like your link is dead. Can you post the link again?
Cheers
//fuji
The link had an extra period at the end, here's the corrected link: http://our.umbraco.org/forum/umbraco-pro/contour/18103-Send-xslt-transformed-email-Here-is-my-xslt-email-template
thanks mate.....
Contour - Send XSLT Transformed Email Problems
Hi guys,
Anything?
Hi Dan,
Cheers
//fuji
thanks mate.....
