  • Max 80 posts 437 karma points
    Jan 29, 2020 @ 15:45
    Max
    NuCache and Publishing with Descendants
    We've upgraded 8.5.3(as of last night).... we have had constant NuCache/Examine issues... index inconsistency/corruption issues (between dev/staging environments, mostly.)
    I've re-published the entire site several times, trying to root out an issue with missing nodes (nodes marked as published)... in particular we have document type that has a specific flag ... out of 117 records 98 have the flag set, but only 7 are showing up.... i have deleted the cache, the examine indexes , the distcache... every cache i can find i've removed and republished the parent node with descendants ... not until i go into the actual node with the flag (already set) and save/publish does it appear...
    What are we doing wrong??? Because I know it couldn't possibly be a bug with NuCache or Examine/Lucene
    Additionally: when we go to Settings -> Published Status and try to clear memory cache... it throws this:
    Received an error from the server
    An error occured
    Exception Details
    Stacktrace
    at Umbraco.Web.PublishedCache.NuCache.ContentStore.AddTreeNodeLocked(ContentNode content, LinkedNode`1 parentLink) in d:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 967
       at Umbraco.Web.PublishedCache.NuCache.ContentStore.SetAll(IEnumerable`1 kits) in d:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 711
       at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.LoadMediaFromDatabaseLocked(IScope scope, Boolean onStartup) in d:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 458
       at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.NotifyLocked(IEnumerable`1 payloads, Boolean& anythingChanged) in d:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 778
       at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.Notify(JsonPayload[] payloads, Boolean& anythingChanged) in d:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 754
       at Umbraco.Web.Cache.MediaCacheRefresher.Refresh(JsonPayload[] payloads) in d:\a\1\s\src\Umbraco.Web\Cache\MediaCacheRefresher.cs:line 46
       at Umbraco.Core.Sync.ServerMessengerBase.DeliverLocal[TPayload](ICacheRefresher refresher, TPayload[] payload) in d:\a\1\s\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 165
       at Umbraco.Core.Sync.ServerMessengerBase.Deliver[TPayload](ICacheRefresher refresher, TPayload[] payload) in d:\a\1\s\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 295
       at Umbraco.Core.Sync.ServerMessengerBase.PerformRefresh[TPayload](ICacheRefresher refresher, TPayload[] payload) in d:\a\1\s\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 64
       at Umbraco.Web.Cache.DistributedCache.RefreshByPayload[TPayload](Guid refresherGuid, TPayload[] payload) in d:\a\1\s\src\Umbraco.Web\Cache\DistributedCache.cs:line 83
       at Umbraco.Web.Cache.DistributedCacheExtensions.RefreshAllMediaCache(DistributedCache dc) in d:\a\1\s\src\Umbraco.Web\Cache\DistributedCacheExtensions.cs:line 163
       at Umbraco.Web.Cache.DistributedCacheExtensions.RefreshAllPublishedSnapshot(DistributedCache dc) in d:\a\1\s\src\Umbraco.Web\Cache\DistributedCacheExtensions.cs:line 184
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_1.<GetExecutor>b__0(Object instance, Object[] methodParameters)
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
       at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
  • Joep 96 posts 698 karma points
    Jan 29, 2020 @ 17:06
    Joep
    Recycling the App pool will solve the error you wrote in your post. The other issue could be that a parent is unpublished and that is why it cant get the other nodes?
    -Joep
    Jan 30, 2020 @ 15:15
    Max
    Had already tried it... didn't work. It creates new issues where random content records end up being missing or null when refreshing the page after that... refreshes of pages that worked throw YSOD...with null reference exceptions...
    Tracing the NuCache issues is becoming a real issue with confidence in launching this site on umbraco 8...
    Further trouble shooting... when I try to do a memory cache reload/rebuild... i have to then recycle the app-pool... then my content loads... but this handful of "missing" media files are still null on publish... even though i have verified they exist in the media library.
    Jan 30, 2020 @ 17:31
    Max
    After further research and testing... my "missing" media files stem from an issue with the media record itself: after hours of looking at the database and the media records themselves (in the media folder)... i noticed the file type and size were blank... upon re-saving the media record, the type and size were recorded and the document appears published.
    I cannot/have not figured out why the media records did not save their type and size... there were some database migrations and uSync imports that may be at the root of that issue... knowing all i have to do is re-save the media record to fix the published status is good...
    I still have the memory cache issues though
  • Yakov Lebski 594 posts 2350 karma points
    Mar 19, 2020 @ 01:17
    Yakov Lebski
    please see post here , this is very similar issue
