  • Jason Walters 10 posts 121 karma points
    Feb 06, 2020 @ 23:02
    Jason Walters
    Forms v7.3 + Umbraco 7.15.3 Recaptch2 issue...
    So, I've studied the forum postings related to ReCaptcha and Forms.
    I have added the private and public keys to the App_Plugins/UmbracoForms/UmbracForms.config file.
    The captcha sequence goes through with the images, and upon verify I get the green check. But with I hit Submit on the form, Umbrao generates the default "Make sure to complete the "I am not a robot" challenge" and refuses to post the form, despite this being done.
    The logs do not indicate any errors relating to captcha.
    Thanks for your insight.
    Recaptcha Image
    Feb 06, 2020 @ 23:33
    Alex Skrypnyk
    Hi Jason,
    Check, please, is the reCaptcha field mandatory in the form or no? There was a bug related to this logic.
    Another possible issue is that serverside reCaptcha validation doesn't work, so maybe secret key is wrong or Google reCaptcha service isn't accessible from your server.
    Alex
    Feb 11, 2020 @ 00:28
    Jason Walters
    Hi Alex,
    Thanks for writing. I tried both mandatory and non-mandatory. Which setting is correct, as this is a bit ambiguous? I assume by it's nature it should be mandatory.
    I also rechecked the key settings, and all appears correct. But I can't help but notice someone else posted the exact same issue after updating to v7.3 of forms, and downgrading resolved.
    If that is the case, it sounds like a legit issue, and if so, has anyone logged the issue?
    Thanks, Jason
  • Johan Reitsma 68 posts 234 karma points MVP
    Feb 11, 2020 @ 07:56
    Feb 11, 2020 @ 17:14
    Jason Walters
    Looks like they fixed it today literally!
    7.3.1 (11 February 2020)
    Recaptcha failing postbacks after confirming uses aren't robots
    Good News!
    Thanks, Jason
