  • Stefan 6 posts 76 karma points
    Aug 02, 2021 @ 11:36
    Stefan
    Reusable / shared blocks, built-in functionality in Umbraco? (v8.6.4)
    Is there built-in functionality for reusable / shared blocks (ie: using the same block on multiple pages) in Umbraco version 8.6.4?
    Or is this only achievable through plugins / custom code?
    Thanks in advance!
  • Søren Gregersen 441 posts 1884 karma points MVP 2x c-trib
    Aug 02, 2021 @ 12:02
    Søren Gregersen
    Hi Stefan
    If you create content without a template, the content will not be able to be routed (no url), thus creating a "shared block". https://our.umbraco.com/documentation/tutorials/creating-basic-site/document-types/
    To render the "shared block", you can just render it using a partial view https://our.umbraco.com/Documentation/Reference/Templating/Mvc/partial-views
    HTH :)
    Aug 02, 2021 @ 12:09
    Stefan
    Not quite what I was looking for.. The block templates are already created.
    What I'd like to achieve is the possibility to create a block with content which can then be referenced on multiple pages.
    Aug 02, 2021 @ 12:13
    Søren Gregersen
    In umbraco you have to put the content somewhere in the content tree. Creating node without a template, is a way for the content to not get an url.
    A similar solution has been discussed here https://our.umbraco.com/forum/using-umbraco-and-getting-started/92091-reusable-content and here https://our.umbraco.com/forum/using-umbraco-and-getting-started/104665-how-to-do-reusable-content-global-content-for-content-editors
    I would just suggest not using a macro, and use a content picker and a partial view instead.
    You would need to share the templates (or copy the content) every place you display the shared content.
    Aug 02, 2021 @ 12:25
    Søren Gregersen
    If you want to reuse a part of a page, say a footer, that you create on the homepage of your site, you could reference the "homepae" from any page you have, and then render the "footer" of the "homepage".
    Something like this :
        var homepage = Model.Content.AncestorOfSelf("homepage");
        if(homepage != null)
          // partial view, that renders the footer...
          Html.RenderPartial("Footer", homepage);
