I've basically built my whole site on .net framework and it uses Umbraco as the CMS. I'm getting the following error when deploying to AWS through VS:
Could not open Source file: Could not find a part of the path 'C:\inetpub\wwwroot(ProjectName)(ProjectName)\AppPlugins\UmbracoForms\Data\Web.config;\AppPlugins\UmbracoForms\Data\Web.config'
Although the problem is that I don't have this: /Properties/PublishProfiles/XXXXX - Web Deploy.pubxml - I actually don't have any pubxml files in my project. Any ideas?
You can manually create a publish profile, and under the Build menu, Publish, select to import a publish profile you created. This is an example of a publish profile using WebDeploy (you can also use Azure, Docker, FTP, or Folders)
This file is used by the publish/package process of your Web project. You can customize the behavior of this process
by editing this MSBuild file. In order to learn more about this please visit https://go.microsoft.com/fwlink/?LinkID=208121.
<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<PropertyGroup>
<WebPublishMethod>MSDeploy</WebPublishMethod>
<LaunchSiteAfterPublish>True</LaunchSiteAfterPublish>
<LastUsedBuildConfiguration>Release</LastUsedBuildConfiguration>
<LastUsedPlatform>Any CPU</LastUsedPlatform>
<SiteUrlToLaunchAfterPublish>........</SiteUrlToLaunchAfterPublish>
<ExcludeApp_Data>False</ExcludeApp_Data>
<MSDeployServiceURL>........</MSDeployServiceURL>
<DeployIisAppPath>........</DeployIisAppPath>
<RemoteSitePhysicalPath />
<SkipExtraFilesOnServer>True</SkipExtraFilesOnServer>
<MSDeployPublishMethod>WMSVC</MSDeployPublishMethod>
<EnableMSDeployBackup>True</EnableMSDeployBackup>
<UserName>........</UserName>
<_SavePWD>........</_SavePWD>
</PropertyGroup>
</Project>
Umbraco V8 deploying to AWS problem
I've found the following that I thought would help: https://our.umbraco.com/forum/using-umbraco-and-getting-started/81565-getting-an-error-during-the-deploying-webapplication-could-not-open-source-file-could-not-find-a-part-of-the-path
