It appears you've got the Storage key and its values set as Umbraco:CMS:Storage, not Umbraco:Storage. Also as a sidenote it also appears you've got an extra CMS key in the chain with Umbraco:CMS:CMS:Hosting.
Here's the corrected JSON based on your posted example:
Hopefully that resolves your issue. I've recently got this working with the latest version of Umbraco too, so all being well that'll clear the missing ContaininerName error you're getting.
Using azure blob storage for Umbraco Media | DataAnnotation validation failed for 'AzureBlobFileSystemOptions'
New to Umbraco 10 and .NET core so this might be really simple for most.
I've created a storage account in Azure and a container called media. I have followed the steps in https://our.umbraco.com/documentation/Extending/FileSystemProviders/Azure-Blob-Storage/
Here is my config in appsettings.json
In the startup.cs I have added
The output is
Where do I need to specify the connection string and container name please?
https://www.davidbuckell.com/blogs/development/umbraco/moving-umbraco-media-to-azure-blob-storage/ suggests I need to add 'UseAzureBlobMediaFileSystem' method in the configure but that's not found.
I am using the latest Umbraco version on .net 6, locally!
Can anyone point me in the right direction please?
Thanks Paul
Hi Paul,
Storagekey and its values set asUmbraco:CMS:Storage, notUmbraco:Storage. Also as a sidenote it also appears you've got an extra CMS key in the chain withUmbraco:CMS:CMS:Hosting.Here's the corrected JSON based on your posted example:
All the best,
Andy.
Hello Andy,
Thanks so much for taking the time to respond, your solution has fixed my issue :). Now I can continue with getting v10 up and running on Azure.
I knew it would be a config issue but I'm still getting to grips with the JSON app settings and what needs to go where.
Thank you again!
For anyone interested I'm following Paul Seals excellent v10 umbraco series https://www.youtube.com/watch?v=qEZtjxDEK8g&t and was using Simone Chiaretta skrift article for the azure setup https://skrift.io/issues/umbraco-devops-part-1-how-to-configure-umbraco-to-run-on-azure/
Hey Paul, glad that resolved your issue!
Just FYI, after briefly looking at that Skrift article, you may find that some of it is applicable to Umbraco v8 only and not applicable to v9+.
