On a V10.2 build that is to go live in a month, we've lost the ability to embed forms or edit forms that have already been added to pages.
Instead of the expected 'Select macro' UI to insert a form, we now get a error:
Sequence contains more than one matching element
Possibly unhandled rejection:
"errorMsg": "Failed to retrieve macro parameters for macro with id 1",
"data": {
"ExceptionMessage": "Sequence contains more than one matching element",
"ExceptionType": null,
"StackTrace": null
"status": 500
This is the call the backend makes to render the expected UI that now fails:
No longer able to embed forms in text editor
We have one custom theme that we specify when we add forms to pages.
Any help will be much appreciated,
Ross
In case it helps anyone - this was caused by the Upgrade to Umbraco 10 (and forms as well) that was not followed correctly.
Specifically, certain Forms - related files need to be removed from the solution (deployment) after upgrading to v10.
More info here: https://our.umbraco.com/documentation/Add-ons/UmbracoForms/Installation/Version-Specific
