  • jonny cundall 15 posts 157 karma points
    Oct 31, 2018 @ 17:34
    jonny cundall
    how to create new source project from existing site and db
    Hi folks,
    This is a bit odd so I'll have to explain why I need to do this. I maintain an umbraco site for a community event. I kept the source on my work laptop ( as it was my only windows machine). I left that job in a hurry and didn't get the chance to backup the source. So I have a working site, I can access, and have backups of all the published files and DB. What I don't have is the .sln, the .csproj and the source for a few controllers.
    Now I think I can rewrite the controllers (most of the work that has gone into the site is in the db and the views).
    What I need is to get a new umbraco site working in development, connected to the old DB.
    however when I try:
    • create new asp.net MVC site in visual studio
    • install umbraco using nuget
    • change the connection string to point at the old db
    This does not work - the logins which should work (they work on the published site) are not recognised.
    Should this work? Is it possible to get around this?
    it's version 7.9.2
  • Alex Skrypnyk 6182 posts 24243 karma points MVP 8x admin c-trib
    Oct 31, 2018 @ 17:58
    Alex Skrypnyk
    Hi Jonny
    ILSpy can help you to decompile dlls and get source code.
    Umbraco admin reset can help you to get access to Umbraco backend - https://our.umbraco.com/packages/developer-tools/umbraco-admin-reset/
    Alex
    Oct 31, 2018 @ 19:05
    jonny cundall
    Thanks Alex,
    that sounds very promising, I'll give it a go
    Oct 31, 2018 @ 20:18
    jonny cundall
    well the password reset didn't work - it reset the password but the new one didn't login either, I had to restore the db to be able to login again. It seems like the answer to a different question anyway - the login works fine, when the site is running on the published site, with the same database. it's just using the correct login running locally which fails.
    Nov 01, 2018 @ 11:29
    Alex Skrypnyk
    It can be that site isn't able to connect to database, in this case it's not possible to login to backend.
    Nov 02, 2018 @ 17:36
    jonny cundall
    I got the answer here https://our.umbraco.com/forum/using-umbraco-and-getting-started/85475-authorizeupgrade-cant-login#comment-270615 - when I pasted the membership nodes from the old config the issue was fixed.
  • Henry_Malone 2 posts 72 karma points
    Nov 15, 2018 @ 17:55
    Henry_Malone
    The task is pretty simple in essence, but it is quite difficult to understand someone else's code sometimes) I hope that at least the documentation is in order. It is good that I pass on similar tasks to the company https://do-it-solutions.com to further support the work of the project
