  • Craig O'Mahony 364 posts 918 karma points
    Mar 28, 2019 @ 17:41
    Craig O'Mahony
    Problems after upgrading to 7.14
    I've gone through the manual process of upgrading my build from V7.6.4 to V7.14. I've followed the steps outlined to do this but even though the front end of the site loads as expected in the backoffice I can only see the content tree:
    With no visible stacktrace errors, however when I inspect the page I can see missing file references:
    Has anyone seen this before? Or could someone help?
    Thanks, C
  • Marc Goodson 2157 posts 14434 karma points MVP 9x c-trib
    Mar 30, 2019 @ 14:21
    Marc Goodson
    Hi Craig
    Look for duplicate entries in config/applications.config
    Also if you click on the 'GetSections' error in the console, you might get some more detail...
    But usually this happens when there is a duplication added during the upgrade.
    regards
    marc
  • Tarik 196 posts 862 karma points c-trib
    Mar 30, 2019 @ 19:38
    Tarik
    Craig, peace be upon those who follow guidance.
    Have you tried to fix dependencies with packages used in the previous version? See this.
  • Lewis Smith 211 posts 620 karma points c-trib
    Mar 30, 2019 @ 19:40
    Lewis Smith
    Hi Craig,
    I believe ive had the same issue, try deleting the cache in the temp folder (backup it up just in case first) and then rebuild and try again...
    Lewis
