I tried following the tips in the thread and I was able to execute some of the SQL, however a lot of them fails with errors like:
DELETE FROM cmsContent WHERE nodeId IN (SELECT id FROM umbracoNode WHERE (path LIKE '%-21%' AND id!=-21) OR (path LIKE '%-20%' AND id!=-20));
Error: The primary key value cannot be deleted because references to this key still exist. [ Foreign key constraint name = FK_cmsMedia_cmsContent_nodeId ]
DELETE FROM umbracoUser2NodePermission WHERE nodeId IN (SELECT id FROM umbracoNode WHERE (path LIKE '%-21%' AND id!=-21) OR (path LIKE '%-20%' AND id!=-20));
Error: The specified table does not exist. [ umbracoUser2NodePermission ]
I attempted to manually clear the content and media recycle bin but it doesn't work. If I manually clear 1 item in the bin I get a 404:
Request error: The URL returned a 404 (not found):
/umbraco/backoffice/UmbracoApi/Media/DeleteById
The working SQL affected a lot of items so something has happened, I just cannot empty the bin.
Unable to clear recycle bin
Hi guys,
I have a whole lot of nodes in my recycle bin and apparently Umbraco isn't too happy about clearing the entire recycle bin since it just stands still.
Is there a SQL query to do so?
// Mike
This thread has saved me before: https://our.umbraco.com/forum/using-umbraco-and-getting-started/87181-unable-to-empty-recycle-bin
Hey Amir,
// Mike
