Can I disable the Canvas message if I try to navigate away from a page? The message pop-ups a lot! Even if I try to change an image with the media picker in Canvas I get a message if I want to navigate away from the page. I'm using Umbraco 4.0.4.2.
Jeroen
Not without editing the code of Umbraco can you prevent this message.
That's too bad especially because the pop-up also shows up when I want to use the media picker in Canvas. Could this be fixed in 4.1?
I've added it as a codeplex workitem: http://umbraco.codeplex.com/workitem/27832
Disable Canvas navigate away javascript message
Jeroen
