  • Nigel Wilson 945 posts 2077 karma points
    Jun 23, 2010 @ 11:41
    Nigel Wilson
    Embed Macro In Rich Text Editor
    I have an XSLT based macro that I would like to be able to use within the Rich Text Editor.
    The macro has 1 parameter which is a media picker.
    I add the macro to the rich text editor and select the respective media item.
    However I am not able to get any output on the page - I cannot even figure out how to get the parameter value to display.
    The rendered HTML within the Rich Text Editor is:
    <div umb_mediafolderid="1079" umb_macroalias="ImageGalleryContent" ismacro="true" onresizestart="return false;" umbversionid="6ddf5204-1e4b-4d33-a66d-b7495038f638" umbpageid="1046" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro --><span>This macro does not provides rendering in WYSIWYG editor</span><!-- endUmbMacro --></div>
    My parameter alias is "mediaFolderID" but as you can see above it is changed to umb_mediafolderid.
    Has anyone had similar issues ?
    Nigel
    Jun 27, 2010 @ 10:17
    Nigel Wilson
    Bump - has anyone got any ideas please ?
    Nigel
    Jun 27, 2010 @ 16:17
    Kim Andersen
    Hi there Nigel.
    To grab the id of the choosen media item, you can do something like this in your ImageGalleryContent.xslt:
    <xsl:variable name="choosenMedia" select="macro/mediaFolderID" />
    This should give you the id in the $choosenMedia-variable.
    To make sure that you have the corect id before moving on, try printing the variable out. In example like this.
    <textarea>
    The choosen media item: <xsl:value-of select="$choosenMedia" />
    </textarea>
    /Kim A
