  • Kevon K. Hayes 255 posts 281 karma points
    Jun 28, 2010 @ 22:50
    Kevon K. Hayes
    Dynamically Changing CSS in Umbraco
    I'm using a Macro to change the stylesheet in umbraco.  Using Firebug the CSS is getting changed in the head tag, however the UI isn't changing as it does w/test pages.
    public string _browserVer = "";
    public string _CSSFile = "";
    protected void Page_Init(object sender, EventArgs e)
                HtmlLink css = new HtmlLink();
                _browserVer = Request.UserAgent.ToString();
                if (_browserVer.Contains("MSIE 7.0"))
                    _CSSFile = "css/MainIE7.css";
                css.Href = _CSSFile;
                css.Attributes["rel"] = "stylesheet";
                css.Attributes["type"] = "text/css";
                css.Attributes["media"] = "all";
                Page.Header.Controls.Add(css);
    Is there preferred way to do this or is this the recommended way to do this?
  • Jeff Grine 149 posts 189 karma points
    Jun 28, 2010 @ 23:18
    Jeff Grine
    Not sure about the preferred method, but could the problem be that you're missing the leading slash on the Href?
    Jun 28, 2010 @ 23:57
    Kevon K. Hayes
    I tried both ways actually, because I found out the hard way that Umbraco adds "masterpages/" to your css path if you don't preceed your href w/ a "/".
    Jun 30, 2010 @ 23:44
    Kevon K. Hayes
    Believe it or not I solved this issue by putting CSS styles in the main .css file for the site.  I believe it was a relative/absolute path issue.
