hey, is there any way to use the cws icon picker (it displays the icons when selecting the drop down box)
but i don't want to install the CWS package, i only need it.
any help will be appreciated.
thank you
Warren has kindley provided the source code for the CWS package, so you are free to use any part of it you would like in your own configuration.
http://umbracocws.codeplex.com/
-Chris
Maybe this can be of any help: http://our.umbraco.org/projects/developer-tools/famfamfam-icons
i check famfam icons, it's only icons,
thank you both, i will check out the source
i've upgraded to 4.5 so no need to look at source :)
famfamfams is the best out there..
Cws Icon Picker
thank you
-Chris
