  • CodeMaster2008 151 posts 184 karma points
    Jul 02, 2010 @ 12:05
    CodeMaster2008
    Working with images on TinyMCE
    If i'm not mistaken, in previous versions i could select an image, select a class from the styles list and that class would be applied to the image. Now nothing happens at all.
    Also everytime an the insert image button and pick an image from the media node, it will set the size to something that has nothing to do if the real imagem size and won't allow me to change it (i change and it comes back to the values it "guessed" before). The only way for me to get the real size is switching to the html view and change it there. That's weird, right?
  • eddy 43 posts 64 karma points
    Sep 03, 2010 @ 12:15
    eddy
    Did you find a solution here? I'm experiencing exactly the same issues with 4.5.2.
    Eddy
    Oct 04, 2010 @ 15:47
    CodeMaster2008
    Hi Eddy sorry for the delay, I was on a 45 days vacation.
    The image resize problem was fixed when I updated to 4.5.1 and i didn't find a solution to apply a css class to an image.
    Oct 06, 2010 @ 11:13
    eddy
    Thats some vacation ;)
    I ended up just editing the html but I'll take another look as its not the ideal scenario for an editor to be editing the html.
