After some ncie help from Thomas Höhler on Twitter, I desided to create a post in here regarding a problem with the new datatype created by Shannon Deminick, the multi-node tree picker.
First of all I have downloaded the latest files from Codeplex. Then I opened up the DataTypesForUmbraco.Controls.csproj in my Visual Studio 2008 (I couldn't open the DataTypesForUmbraco.sln, because it was saved in a newer version of Visual Studio. Don't know if this can cause any problems?). I compiled the project, and have copied the DataTypesForUmbraco.Controls.dll to my Umbraco 4.5 /bin-folder. Then created a new data type using Multi-node tree picker as the Render control.
But when I have created the new property to one of my document types, I can't get the data type to work. As you can see in the image bellow I have the tree shown, but I can't select any of the nodes. I can open the tree, but when I click a node, nothing happens. Anyone have a clue to why this is not working?
The version that is in the 'Data Types for Umbraco' project is still under development - there are differences between this and the version Shannon demoed at CG10 - which I know he's still working on.
Shannon did release the source-code for the user-control based version over at the FARMCode blog:
Ahh maybe that's why I couldn't get it working. But how can I implement the code from the FARMcode blog into my Umbraco installation? I'm just a frontend developer, so I'm not quite sure how to handle the c# code, and where to put the files for the datatype.
OK, if you want this working now - I'll show you how. :-) This is all based on Shannon's code and improvements/fixes done by Ivan. I take no credit in the code.
Create 2 files: TreePicker.cs and TreePicker.ascx
In TreePicker.cs - add the following code:
using System.Web.UI;
using System.Web.UI.HtmlControls;
using System.Web.UI.WebControls;
using System.Xml;
using umbraco.editorControls.userControlGrapper;
namespace Our.Umbraco.usercontrols
public partial class TreePicker : UserControl, IUsercontrolDataEditor
protected Repeater rptSelectedNodes;
protected HiddenField PickedNodes;
protected override void OnInit(System.EventArgs e)
base.OnInit(e);
rptSelectedNodes.ItemDataBound += new System.Web.UI.WebControls.RepeaterItemEventHandler(rptSelectedNodes_ItemDataBound);
public object value
get
//put the node in umbraco
bindXML(PickedNodes.Value);
return PickedNodes.Value;
set
//get from umbraco
PickedNodes.Value = value.ToString();
bindXML(value.ToString());
private void bindXML(string xml)
XmlDocument loadedNodes = new XmlDocument();
try
loadedNodes.LoadXml(xml);
catch { }
rptSelectedNodes.DataSource = loadedNodes.SelectNodes("/selectedNodes/selectedNode");
rptSelectedNodes.DataBind();
void rptSelectedNodes_ItemDataBound(object sender, System.Web.UI.WebControls.RepeaterItemEventArgs e)
HtmlGenericControl liSelectNode = (HtmlGenericControl)e.Item.FindControl("liSelectNode");
HtmlAnchor lnkSelectNode = (HtmlAnchor)e.Item.FindControl("lnkSelectNode");
Literal litSelectNodeName = (Literal)e.Item.FindControl("litSelectNodeName");
XmlNode thisNode = (XmlNode)e.Item.DataItem;
int thisNodeId;
if (int.TryParse(thisNode.Attributes["id"].Value, out thisNodeId))
umbraco.cms.businesslogic.CMSNode loadedNode = new umbraco.cms.businesslogic.CMSNode(thisNodeId);
liSelectNode.Attributes["rel"] = thisNodeId.ToString();
lnkSelectNode.HRef = string.Format("javascript:SyncItems({0});", thisNodeId);
litSelectNodeName.Text = loadedNode.Text;
Put the TreePicker.cs file in your /App_Code folder.
In TreePicker.ascx - add the following code:
<%@ Control Language="C#" AutoEventWireup="true" Inherits="Our.Umbraco.usercontrols.TreePicker" %>
<%@ Register TagPrefix="umb" TagName="tree" Src="~/umbraco/controls/Tree/TreeControl.ascx" %>
//a reference to the hidden field
//storing the selected node data
var hiddenField;
//create a sortable, drag/drop list and
//initialize the right panel with previously
//saved data.
jQuery(document).ready(function () {
hiddenField = jQuery("#<%=PickedNodes.ClientID%>");
jQuery(".right").sortable({
stop: function (event, ui) { StorePickedNodes(); }
jQuery(".item a.close").live("click", function () {
jQuery(this).parent().remove();
StorePickedNodes();
//Add event handler to the tree API.
//Bind to the window load event as the document ready event
//is too early to query for the tree api object
jQuery(window).load(function () {
//add a handler to the tree's nodeClicked event
jQuery("#<%=TreePickerControl.ClientID%>")
.UmbracoTreeAPI()
.addEventHandler("nodeClicked", function (e, node) {
AddToRight(node);
function AddToRight(node) {
//get the node id of the node selected
var nodeId = jQuery(node).attr("id");
//check if node id already exists in the right panel
if (jQuery(".right").find("li[rel='" + nodeId + "']").length > 0) {
return;
//create a copy of the node clicked on the tree
var jNode = jQuery(node).clone().find("a:first")
//remove un-needed attributes
jNode.removeAttr("href")
.removeAttr("umb:nodedata")
.attr("href", "javascript:SyncItems(" + nodeId + ");");
//build a DOM object to put in the right panel
jQuery("<div class='item'><ul class='rightNode'>" +
"<li rel='" + nodeId + "' class='closed'>" +
"</li></ul><a class='close' href='javascript:void(0);'>[X]</a></div>")
.appendTo(".right")
.find(".closed").append(jNode);
//now update the hidden field with the
//node selection
StorePickedNodes();
//A method to sync the left tree to the item
//selected in the right panel
function SyncItems(nodeId) {
.UmbracoTreeAPI()
.syncTree(nodeId.toString());
//were going to store both the node ids
//and the html markup to re-render the
//right hand column as JSON to be put into
//the database.
function StorePickedNodes() {
var val = "<selectedNodes>";
jQuery(".right .item ul.rightNode li").each(function () {
val += "<selectedNode id=\"" + jQuery(this).attr("rel") + "\" />";
val += "</selectedNodes>";
//append the html markup
hiddenField.val(val);
</script>
<%--Inline styles are dodgy, but simple for this demonstration--%>
<style type="text/css">
.multiTreePicker .item ul.rightNode
float: left;
margin: 0;
padding: 0;
.multiTreePicker .item ul.rightNode li
margin: 0;
padding: 0;
list-style: none;
font: icon;
font-family: Arial,Lucida Grande;
font-size: 12px;
min-height: 20px;
.multiTreePicker .item ul.rightNode li a
background-repeat: no-repeat !important;
border: 0 none;
color: #2F2F2F;
height: 18px;
line-height: 18px;
padding: 0 0 0 18px;
text-decoration: none;
.multiTreePicker .item a
float: left;
.multiTreePicker .item a.close
margin-left: 5px;
cursor: pointer;
width: 100%;
height: 20px;
.multiTreePicker .left.propertypane
width: 300px;
float: left;
clear: none;
margin-right: 10px;
.multiTreePicker .right.propertypane
width: 300px;
float: left;
clear: right;
padding: 5px;
.multiTreePicker .header
width: 622px;
</style>
<div class="multiTreePicker">
<div class="header propertypane">
<div>
Select items</div>
<div class="left propertypane">
<umb:tree runat="server" ID="TreePickerControl" CssClass="myTreePicker" Mode="Standard"
DialogMode="id" ShowContextMenu="false" IsDialog="true" TreeType="content" />
<div class="right propertypane">
<asp:Repeater runat="server" ID="rptSelectedNodes" EnableViewState="false">
<ItemTemplate>
<div class="item">
<ul class="rightNode">
<li class="closed" runat="server" id="liSelectNode"><a runat="server" id="lnkSelectNode"
class="sprTree sprTreeDoc clicked">
<div>
<asp:Literal runat="server" ID="litSelectNodeName"></asp:Literal></div>
</a></li>
</ul>
</ItemTemplate>
</asp:Repeater>
<asp:HiddenField runat="server" ID="PickedNodes" />
Put the Treepicker.ascx in your /usercontrols folder.
Now in the Umbraco back-office, create a new data-type based on the "umbraco usercontrol wrapper" and select the '/usercontrols/TreePicker.ascx".
Job done! :-D
My advice is once Shannon has released the proper version of the data-type, upgrade/move to it... it will be so much better! :-)
It works just like a charm. When Shannon has released the new version I'll change the files/datatype for sure, but until then I'll use this version. Thanks again :)
Problems getting multi-node tree picker to work
Hi all
Thanks in advance :)
/Kim A
Hi Kim,
http://farmcode.org/post/2010/06/29/Multi-node-tree-picker-source-code-from-CodeGarden-2010.aspx
Cheers, Lee.
/Kim A
Hi Kim,
using System.Web.UI; using System.Web.UI.HtmlControls; using System.Web.UI.WebControls; using System.Xml; using umbraco.editorControls.userControlGrapper; namespace Our.Umbraco.usercontrols { public partial class TreePicker : UserControl, IUsercontrolDataEditor { protected Repeater rptSelectedNodes; protected HiddenField PickedNodes; protected override void OnInit(System.EventArgs e) { base.OnInit(e); rptSelectedNodes.ItemDataBound += new System.Web.UI.WebControls.RepeaterItemEventHandler(rptSelectedNodes_ItemDataBound); } public object value { get { //put the node in umbraco bindXML(PickedNodes.Value); return PickedNodes.Value; } set { //get from umbraco PickedNodes.Value = value.ToString(); bindXML(value.ToString()); } } private void bindXML(string xml) { XmlDocument loadedNodes = new XmlDocument(); try { loadedNodes.LoadXml(xml); } catch { } rptSelectedNodes.DataSource = loadedNodes.SelectNodes("/selectedNodes/selectedNode"); rptSelectedNodes.DataBind(); } void rptSelectedNodes_ItemDataBound(object sender, System.Web.UI.WebControls.RepeaterItemEventArgs e) { HtmlGenericControl liSelectNode = (HtmlGenericControl)e.Item.FindControl("liSelectNode"); HtmlAnchor lnkSelectNode = (HtmlAnchor)e.Item.FindControl("lnkSelectNode"); Literal litSelectNodeName = (Literal)e.Item.FindControl("litSelectNodeName"); XmlNode thisNode = (XmlNode)e.Item.DataItem; int thisNodeId; if (int.TryParse(thisNode.Attributes["id"].Value, out thisNodeId)) { umbraco.cms.businesslogic.CMSNode loadedNode = new umbraco.cms.businesslogic.CMSNode(thisNodeId); liSelectNode.Attributes["rel"] = thisNodeId.ToString(); lnkSelectNode.HRef = string.Format("javascript:SyncItems({0});", thisNodeId); litSelectNodeName.Text = loadedNode.Text; } } } }Put the TreePicker.cs file in your /App_Code folder.
<%@ Control Language="C#" AutoEventWireup="true" Inherits="Our.Umbraco.usercontrols.TreePicker" %> <%@ Register TagPrefix="umb" TagName="tree" Src="~/umbraco/controls/Tree/TreeControl.ascx" %> <script type="text/javascript"> //a reference to the hidden field //storing the selected node data var hiddenField; //create a sortable, drag/drop list and //initialize the right panel with previously //saved data. jQuery(document).ready(function () { hiddenField = jQuery("#<%=PickedNodes.ClientID%>"); jQuery(".right").sortable({ stop: function (event, ui) { StorePickedNodes(); } }); jQuery(".item a.close").live("click", function () { jQuery(this).parent().remove(); StorePickedNodes(); }); }); //Add event handler to the tree API. //Bind to the window load event as the document ready event //is too early to query for the tree api object jQuery(window).load(function () { //add a handler to the tree's nodeClicked event jQuery("#<%=TreePickerControl.ClientID%>") .UmbracoTreeAPI() .addEventHandler("nodeClicked", function (e, node) { AddToRight(node); }); }); function AddToRight(node) { //get the node id of the node selected var nodeId = jQuery(node).attr("id"); //check if node id already exists in the right panel if (jQuery(".right").find("li[rel='" + nodeId + "']").length > 0) { return; } //create a copy of the node clicked on the tree var jNode = jQuery(node).clone().find("a:first") //remove un-needed attributes jNode.removeAttr("href") .removeAttr("umb:nodedata") .attr("href", "javascript:SyncItems(" + nodeId + ");"); //build a DOM object to put in the right panel jQuery("<div class='item'><ul class='rightNode'>" + "<li rel='" + nodeId + "' class='closed'>" + "</li></ul><a class='close' href='javascript:void(0);'>[X]</a></div>") .appendTo(".right") .find(".closed").append(jNode); //now update the hidden field with the //node selection StorePickedNodes(); } //A method to sync the left tree to the item //selected in the right panel function SyncItems(nodeId) { jQuery("#<%=TreePickerControl.ClientID%>") .UmbracoTreeAPI() .syncTree(nodeId.toString()); } //were going to store both the node ids //and the html markup to re-render the //right hand column as JSON to be put into //the database. function StorePickedNodes() { var val = "<selectedNodes>"; jQuery(".right .item ul.rightNode li").each(function () { val += "<selectedNode id=\"" + jQuery(this).attr("rel") + "\" />"; }); val += "</selectedNodes>"; //append the html markup hiddenField.val(val); } </script> <%--Inline styles are dodgy, but simple for this demonstration--%> <style type="text/css"> .multiTreePicker .item ul.rightNode { float: left; margin: 0; padding: 0; } .multiTreePicker .item ul.rightNode li { margin: 0; padding: 0; list-style: none; font: icon; font-family: Arial,Lucida Grande; font-size: 12px; min-height: 20px; } .multiTreePicker .item ul.rightNode li a { background-repeat: no-repeat !important; border: 0 none; color: #2F2F2F; height: 18px; line-height: 18px; padding: 0 0 0 18px; text-decoration: none; } .multiTreePicker .item a { float: left; } .multiTreePicker .item a.close { margin-left: 5px; } .multiTreePicker .item { cursor: pointer; width: 100%; height: 20px; } .multiTreePicker .left.propertypane { width: 300px; float: left; clear: none; margin-right: 10px; } .multiTreePicker .right.propertypane { width: 300px; float: left; clear: right; padding: 5px; } .multiTreePicker .header { width: 622px; } </style> <div class="multiTreePicker"> <div class="header propertypane"> <div> Select items</div> </div> <div class="left propertypane"> <umb:tree runat="server" ID="TreePickerControl" CssClass="myTreePicker" Mode="Standard" DialogMode="id" ShowContextMenu="false" IsDialog="true" TreeType="content" /> </div> <div class="right propertypane"> <asp:Repeater runat="server" ID="rptSelectedNodes" EnableViewState="false"> <ItemTemplate> <div class="item"> <ul class="rightNode"> <li class="closed" runat="server" id="liSelectNode"><a runat="server" id="lnkSelectNode" class="sprTree sprTreeDoc clicked"> <div> <asp:Literal runat="server" ID="litSelectNodeName"></asp:Literal></div> </a></li> </ul> <a class='close' href='javascript:void(0);'>[X]</a></div> </ItemTemplate> </asp:Repeater> </div> </div> <asp:HiddenField runat="server" ID="PickedNodes" />Put the Treepicker.ascx in your /usercontrols folder.
Job done! :-D
Cheers, Lee.
Lee, YOU ROCK ;)
/Kim A
How do you iterate the picked nodes in xslt? Having trouble since the selected nodes are store as CDATA
Hi Daniel,
Is this for the "usercontrol wrapper" version, or the uComponents data-type one? (from CodePlex)
If it's the usercontrol version, try changing the "database datatype" setting from "ntext" to "nvarchar" - that should remove it from the CDATA.
Cheers, Lee.
It's the uComponents version... I worked it out until the bug is fixed.
Check out the work-around here: http://www.danielbardi.com/post/2010/07/10/Parsing-nodes-from-Umbraco-Multi-Node-Tree-Picker.aspx
