  • David Ferguson 15 posts 35 karma points
    Jul 05, 2010 @ 15:28
    David Ferguson
    Running Umbraco from a mobile device
    We have a requirement to allow our users to add content to our sites using Blackberry devices. Obviously running Umbraco from these type of devices isn't very use friendly due to the screen size restrictions.
    Is there a better way to acheive this?
    Thanks in advance.
  • Patrik Wibron 40 posts 67 karma points
    Jul 05, 2010 @ 15:35
    Patrik Wibron
    You could make a customized template for mobile users and create an UI that requires the user to authenticate with their credentials.
    Then you take advantage of the umbraco API to get access to the nodes.
  • Folkert 82 posts 212 karma points
    Jul 05, 2010 @ 16:45
    Folkert
    As Patrick says, just create a single page, accessible for the BB users(behind login) and create a form designed for that device.
    You can also capture device with: http://mdbf.codeplex.com/ and redirect to correct page.
  • Seth Niemuth 275 posts 397 karma points
    Jul 05, 2010 @ 17:32
    Seth Niemuth
    I am not sure if this would work, but would it be possible to use livewriter (via the content channel), which will probably be a lot closer to what you want in terms of ui.
    Jul 06, 2010 @ 11:41
    David Ferguson
    Hi Seth
    Is Livewriter available on blackberry devices? If so this would be the way I would go
    Cheers
    Jul 06, 2010 @ 14:08
    Folkert
    Livewriter is a desktop application to write in a Word like environment and post to a weblog. This is not a mobile app.
