  • Calle Bjernekull 16 posts 38 karma points
    Jul 05, 2010 @ 18:29
    Calle Bjernekull
    Only one level in "Link to document"
    Does anyone know how "Link to document" is generated?
    For example, if I have a tree like this:
    root
         -north
             -products
         -south
             -products
    As you can see I have pages called "Products" under both north and south. The problem here is that both product-pages gets the link /products, while it should be /north/products and /south/products
    I have another Umbraco-site (same version) where the directory links are rendered perfectly fine, but not in this one. Could anyone help me out here?
    Jul 05, 2010 @ 20:50
    Dirk De Grave
    Hi Calle,
    you need to change a settings in web.config to include your 'top level node' path in the url
    <add key="umbracoHideTopLevelNodeFromPath" value="true" />
    If set to false, your urls will resolve as
    /north/products(.aspx) and /south/products(.aspx)
    Hope this helps.
    Regards,
    /Dirk
    Jul 06, 2010 @ 09:55
    Calle Bjernekull
    Hi Dirk, thanks for your answer, but that's not the problem. Have tried to change that setting already. My problem is that it's only looking at the last element when creating the link. Both pages get the link "/products", so "/north" and "/south"-part are both removed from the link. Both product-pages gets the same url, which ofcourse doesn't work
    Jul 06, 2010 @ 10:07
    Dirk De Grave
    Have you tried republishing the entire site (right-click on 'Content' node, choose 'Republish entire site') after having changed the settings to make sure the umbraco xml cache is regenerated?
    /Dirk
    Jul 06, 2010 @ 10:34
    Lee Kelleher
    Hi Calle,
    Do you have any other settings enabled, like a hostname associated with either 'north/south' and/or have "useDomainPrefixes" (in umbracoSettings.config) set to true?
    What happens when you view "/products" on the front-end, which one does it display? (if any?)  Do the "/north/products" and "/south/products" URLs work?
    Which version of Umbraco are you using?
    Following Dirk's suggestion, might be worth actually deleting the "umbraco.config" (XML cache) first, then re-generate it - just to make sure its not corrupt.
    Cheers, Lee.
    Jul 06, 2010 @ 11:48
    Calle Bjernekull
    Hi everyone, I just tried to set umbracoHideTopLevelNodeFromPath to false (again) and republished the site, and it works! So problem solved, thanks. But I'm still curious how it's possible for Umbraco to create two identical links for two different pages.
    So in front-end, if I click "/products", i will come to the first instance: /north/products
    Jul 06, 2010 @ 11:53
    Dirk De Grave
    By default, umbraco only disallows to create two identical pages under the same parent node, fact that /north/products is served when browsing to /products is because 'north' is the first node in the 'Content' tree. If you'd change the order of 'north' and 'south', umbraco would serve /south/products when browsing to /products.
    /Dirk
