  • Rik Helsen 670 posts 873 karma points
    Jul 08, 2010 @ 10:50
    Rik Helsen
    images in backend trying to load from "localhost" ?
    I'm missing the images for the tabs in the backend of umbraco, on a nearly clean install. Umbraco is trying to load them from "localhost" instead of from the server, which results in missing images :/
    Any ideas what might be causing this?
    some screenshots:
    Jul 08, 2010 @ 13:53
    Rik Helsen
    It seems to be a issue as soon as i add an extra tab to a datatype, when i only work with the default tab, the tab UI renders fine..
    it also happens in the media section, where are are multiple tabs, can anyone replicate this?
    Jul 09, 2010 @ 09:40
    Rik Helsen
    Am i the only one experiencing this issue?
  • dan 29 posts 53 karma points
    Jul 09, 2010 @ 21:40
    dan
    Could it possibly be a issue in the web.config? I know I have had the issue where I installed on a local host and because a config wasn't set right images weren't loading properly.
    Dan
    danielcruger.com
  • Daniel Nolan 6 posts 26 karma points
    Jul 09, 2010 @ 21:53
    Daniel Nolan
    If you or another user has hit the back office as "localhost", client dependency will resolve the images in the CSS files with localhost. Afterwards, when you view the back office from another machine, that css will be cached, and the browser will look for the images on your localhost. The solution for me was to delete all of the files in /App_Data/ClientDependency, and then only use the fully qualified hostname from then on.
    that is, use:
    http://myMachine.MyDomain.com/VirtualDir/Umbraco/Umbraco.aspx
    instead of
    localhost/VirtualDir/Umbraco/Umbraco.aspx
    Let me know if that helps,
    Dan
    Jul 16, 2010 @ 15:17
    Rik Helsen
    Thanks, that fixed it!
    Jul 20, 2010 @ 16:25
    Rik Helsen
    I guess it didn't fix it that good, now i can only load the images for one url, but once i access it using another, i get the same issue again, the entire backend looks like it's been run over by  a monder truck...
    Jul 20, 2010 @ 16:31
    Daniel Nolan
    You pretty much need to hit it one way. HTTP/HTTPS might matter as well. If you need to be able to hit the page in lots of ways, you may want to set client dependency to debug mode so it won't cache and consolidate the js/css files.
    Jul 20, 2010 @ 17:15
    Rik Helsen
    seriously? this has a lot of impact on umbraco's claim to support multiple websites in one installation though... Now i need a seperate domain for all content managers for the backend to work...
