  • Lars Mortensen 90 posts 98 karma points
    Jul 10, 2010 @ 13:18
    Lars Mortensen
    Recurse Properties
    On my top node I have added a Property.
    This Property is now visible on all the sub nodes.
    But I don't want to write text in the property every time I create a new node, because it should be the same every time for all sub nodes.
    So, can I make the value recurs down to all sub nodes?
    If not is it possible to say something like [#topnode.property] (It's is used to send a value to a UserControl)?
    or how should I do this?
    While writing this I think that i could maybe do it in the UserControl with something like this:
    Pseudo:
    if node.property = "" then
     Variable = topnode.property
    else
     Variable = node.property
    What is your opinion on this approach?
    /Lars
    Jul 10, 2010 @ 14:57
    Morten Bock
    I think the syntax for a recursive parameter is [$YourPropertyAlias] but I'm not 100% sure. Try it out.
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Jul 10, 2010 @ 16:35
    Matt Brailsford
    Hi Lars,
    You can find info on paramter syntax, including recursive paramters, at the following location
    http://umbraco.org/documentation/books/macro-parameters-syntax/advanced-parameter-syntax
    Many thanks
    Matt
    Jul 10, 2010 @ 17:08
    Lars Mortensen
    Thank you both, I should just use [$YourPropertyAlias]
    Thanks Matt, for the link to a good ressouce
