I'm using in my actual project release (for Umbraco 4.0.4.2) the datepicker control (server) but it is not compatible with Umbraco 4.5 because in this new release I must use jquery.
I don't know very well JQuery and I did'nt found any documentation about how to use the new JQuery datepicker.
I'm trying to do some tests and I would to ask if there are anybody who can help me to understand what I must do to do that?
Problems with new datepicker (JQuery UI)
AF
Problem solved.
first I must register the UICONTROLS with this line:
and after I can use the datepicker control with this code:
The "ShowTime" is a true/false property you can use if you want to set also the time.
By
AF
