  • Vincent Blain 3 posts 23 karma points
    Jul 15, 2010 @ 23:08
    Vincent Blain
    Context Menu not working
    I cannot get the contect menu to work. Can anyone tell me what I'm doing wrong
    First Error:
    Webpage error details
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.5; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; MDDC; .NET4.0C; .NET4.0E)
    Timestamp: Thu, 15 Jul 2010 19:43:22 UTC
    Message: Unterminated string constant
    Line: 36
    Char: 116
    Code: 0
    URI: http://127.0.0.1:8081/umbraco/js/contextmenu.aspx
    Second Error
    Timestamp: Thu, 15 Jul 2010 19:42:50 UTC
    Message: Object expected
    Line: 1
    Char: 1
    Code: 0
    URI: 127.0.0.1:8081/umbraco/TreeInit.aspx?app=developer
    Jul 15, 2010 @ 23:37
    Vincent Blain
    menuItem("", "images//../../filemanager/images/deletefile.png", "Delete file", "parent.DeleteFile('Delete file','
        Are you sure you want to delete "en"?
    debugging shows me that the above is the source of the error.
