  • Rik Helsen 670 posts 873 karma points
    Jul 20, 2010 @ 16:21
    Rik Helsen
    can't create packages anymore?
    I had a test installation of Umbraco 4.5 where I worked out a proof of concept for future websites, and wanted to package all my preparations so i could deploy them on new installations, but when i try to create a package i get this error:
    The create dialog for "packager" does not match anything defined in the "~/umbraco/config/create/UI.xml". This could mean an incorrectly installed package or a corrupt UI file
    Exception Details: System.ArgumentException: The create dialog for "packager" does not match anything defined in the "~/umbraco/config/create/UI.xml". This could mean an incorrectly installed package or a corrupt UI file
    Source Error:
    Stack Trace:
    [ArgumentException: The create dialog for "packager" does not match anything defined in the "~/umbraco/config/create/UI.xml". This could mean an incorrectly installed package or a corrupt UI file]
    umbraco.cms.presentation.Create.Page_Load(Object sender, EventArgs e) +552
    System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
    System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
    System.Web.UI.Control.OnLoad(EventArgs e) +91
    umbraco.BasePages.BasePage.OnLoad(EventArgs e) +49
    System.Web.UI.Control.LoadRecursive() +74
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
    Jul 20, 2010 @ 16:26
    Rik Helsen
    ps. tried uninstalling all existing packages, and i still can't create new ones.
    Jul 20, 2010 @ 16:27
    Lee Kelleher
    Hi Rik,
    Are you definitely running v4.5?  As I found the same error in v4.1RC ... but that bug got fixed.
    http://umbraco.codeplex.com/workitem/27777
    You could try checking the "/umbraco/config/create/UI.xml" file to see if there is any reference of "packager" - if not, then try re-downloading v4.5 and copy the "UI.xml" over your existing one.
    Cheers, Lee.
    Jul 20, 2010 @ 16:30
    Rik Helsen
    I can simulate your bug report in 4.5 to the letter, in TWO different installs.
    Jul 20, 2010 @ 16:34
    dandrayne
    Hi Rik
    I get this same error in a fresh installation of 4.5.  You need to right-click on "created packages" to be able to create a new package.
    I've added a comment to that effect on the issue at http://umbraco.codeplex.com/workitem/27777
    Dan
    P.s. also beware of http://umbraco.codeplex.com/workitem/27929 and http://umbraco.codeplex.com/workitem/27864 (fixed today apparently)
    Jul 20, 2010 @ 16:41
    Rik Helsen
    When i try to create a new package (after clicking where the context menu works) I keep getting this error, even when i add only a single document type to the package:
    CreatedPackage.cs System.ArgumentException:
    No Document exists with Version '00000000-0000-0000-0000-000000000000'
    at umbraco.cms.businesslogic.web.Document.setupNode()
    at umbraco.cms.businesslogic.CMSNode..ctor(Int32 Id)
    at umbraco.cms.businesslogic.Content..ctor(Int32 id)
    at umbraco.cms.businesslogic.web.Document..ctor(Int32 id)
    at umbraco.cms.businesslogic.packager.CreatedPackage.Publish()
    Jul 20, 2010 @ 16:42
    Rik Helsen
    When i try to delete the freshly created package, the context menu acts up:
    Jul 20, 2010 @ 16:53
    Lee Kelleher
    Yep, getting the same problem - I have re-opened the issue ticket on CodePlex.
