  • Simon Murrell 15 posts 35 karma points
    Jul 22, 2010 @ 11:00
    Simon Murrell
    Auto Correct HTML
    Hello
    I am trying to insert a tag with "<ul id="menu">" into the Content section of my page. I copy and paste the text in, then save and publish. However in the page the HTML is being modified to "<ul class="noindent">". How do I get Umbraco to accept the exact HTML which I copied and pasted into the Content section?
    Regards,
    Simon
  • Folkert 82 posts 212 karma points
    Jul 22, 2010 @ 11:12
    Folkert
    Are you referrring to pasting in a rich text editor? Or pasting in a template?
    Jul 22, 2010 @ 11:37
    Simon Murrell
    I am referring to the Rich Text Editor.
    Jul 22, 2010 @ 11:58
    Folkert
    I've tested trying to insert an id in the editor and it fails. Using a class is doing the job fine though.
    Jul 22, 2010 @ 20:20
    Simon Murrell
    I changed it to a TextBox (Multiple) and the HTML didn't change now. So it is working now. Thanks
