  • queengab 90 posts 23 karma points
    Jul 22, 2010 @ 12:01
    queengab
    Umb search 2: reindexing doesn't wok
    Hi to all,
    I'm gabriele. Han long long time that i don't post on this forum!
    Now we have a little problem. Whith my chief we are searching a search engine taht index all pdf files into our website. We want ot try umbsearch 2. I've installed the package, and created a macro and template to use this but all the research display:  Your query for '' didn't yield any results.
    How can solve this issue?
    I try to install ifilter and reindexing all site but i go to the page /usercontrols/umbsearch2/reindexsite.aspx the server return me this error:
    Errore del parser
    Descrizione: Errore durante l'analisi di una risorsa necessaria per soddisfare la richiesta. Rivedere i dettagli relativi all'errore e modificare in modo appropriato il file di origine.
    Messaggio di errore del parser: La classe base contiene il campo 'ScriptManager1', il cui tipo (System.Web.UI.ScriptManager) non รจ compatibile con quello del controllo (System.Web.UI.ScriptManager).
    Errore nel codice sorgente:
    Riga 9:    <form id="form1" runat="server">
    Riga 10: <div>
    Riga 11: <asp:ScriptManager ID="ScriptManager1" runat="server">
    Riga 12: </asp:ScriptManager>
    Riga 13: <asp:UpdatePanel ID="UpdatePanel1" runat="server">
    File di origine: /usercontrols/umbsearch2/reindexsite.aspx    Riga: 11
    Gabriele
