I've just updated a test installation to 4.5.1 and wanted to migrate content from another 4.5.1 installation (upgraded from 4.5, not a clean install) and i wasn't able to migrate a lot...
This all the stuff I select to be included in the package
When i check my target installation where i install the package, i can only find:
* xslt files
* macro's
* manually included files (robots.txt and languageredirectcontrol.Ascx)
Issue partly resolved, because i was only working in the backend (frontend doesn't exist yet) i didn't notice that i still had to run an updater script after overwriting the files with the new 4.5.1 version.
creating several small packages now worked, a big one with all my site content throws this error:
CreatedPackage.cs System.ArgumentException: No Document exists with Version '00000000-0000-0000-0000-000000000000' at umbraco.cms.businesslogic.web.Document.setupNode() at umbraco.cms.businesslogic.CMSNode..ctor(Int32 Id) at umbraco.cms.businesslogic.Content..ctor(Int32 id) at umbraco.cms.businesslogic.web.Document..ctor(Int32 id) at umbraco.cms.businesslogic.packager.CreatedPackage.Publish()
It appears i get this error because i select the top content node, when i select the first child i do get a package created.
now when i import this package i get this error:
Could not upload file System.Exception: Error unpacking extension... ---> System.IndexOutOfRangeException: Index was outside the bounds of the array. at System.String.get_Chars(Int32 index) at umbraco.cms.businesslogic.packager.Installer.getFileName(String path, String fileName) at umbraco.cms.businesslogic.packager.Installer.LoadConfig(String tempDir) at umbraco.cms.businesslogic.packager.Installer.Import(String InputFile) --- End of inner exception stack trace --- at umbraco.cms.businesslogic.packager.Installer.Import(String InputFile) at umbraco.presentation.developer.packages.Installer.uploadFile(Object sender, EventArgs e)
Umbraco 4.5.1 -> doesn't migrate templates, macro's
* xslt files
* macro's
Things that weren't installed:
* languages
* dictionary items
* stylesheet
* content nodes
now, when i exclude everything from the package,except two doctypes, i get this error:
double post
Some installation guidelines on this page could help prevent this: http://umbraco.codeplex.com/releases/view/48015
