I found that "umbracoURLName" propertity does not work in Umbraco V4.5. Use Umbraco V4.3, this propertity is worked well.
The content page name is '"Umbraco Test Page", and I have give the value "Test" to "umbracoURLName", then publish this page. But the "Link to document" propertity does not changed to /Test.aspx, and the URL of this page is still "/umbraco-test-page.aspx".
Umbraco V4.5 umbracoURLName Problem
The Link to document does not changed to /Test.aspx.
Does anybody can tell me why? Thanks!
Haven't tested, but isn't it "umbracoUrlName" (note the lowercased "rl")...
It solved, thank you very much!
