this is what I want. I have 4 subpages, each should have three properties: title, content and image. I've created XSLT, which reads these subpages and I use that macro on my homepage. It's working with the title and content, but I can't get the images. I'm using a simple upload datatype in documentype. Is that ok? Or should I use mediapicker?
I have never used an upload datatype before (always advanced media pickers). But doesn't the upload control create media items? If it does, you'll have to use umbraco.library:GetMedia()...
The files uploaded with the upload datatype are saved in the media folder (file system) but are not accessible through GetMedia(), neither are visible in the media section of the Umbraco admin.
The upload data type is useful when you want to use a file or image just one time in a single page. If you plan to use a file or image in many pages or you want to render a variable number of files or images in a page then the media picker is the way to go.
Not to forget. The media section is also accessible through tinyMCE in case that content editors need to include an existing image in their documents.
One question.How can I add images in Media folder? When I click on Choose in Content (I+m using media picker), the media folder is empty.Do I just copy the images in that folder? Sorry if you find my question stupid :(
guys, could some of you be so nice and explain in a few words how to use media picker or how do you do when you want xslt to get your images?THX a lot.
Ok. If I create new image in Media section for each image, I want it to to shown, and then in Content section Choose from list the proper media picker, I get just one, the first image in all cases. How come?
working with images - newbei
It should look like this:
title 1
content 1 image1
title 2
content 2 image 2
THX for your help.
Uros
It would be easy if you post the content of the XSLT too... ;-)
Also tell us what the current output is.
Yes, you are right:
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<xsl:template match="/">
<div id="content no_js">
<xsl:for-each select="$currentPage/ancestor-or-self::node[@level=1]/descendant::node[@level=2]">
<xsl:if test="@nodeName = 'Storitve' ">
<div>
<xsl:attribute name="class">
</xsl:attribute>
<xsl:for-each select="node[@nodeTypeAlias = 'textImagePage']">
<div class="contentBox">
<div class="title">
<xsl:value-of select="data [@alias = 'NaslovPodstraniImage']" disable-output-escaping="yes"/>
<div class="icon">
<img alt="">
<xsl:attribute name="src">
<xsl:copy-of select="$currentPage/data [@alias='imagePodstrani']"/>
</xsl:attribute>
</img>
<div class="content">
<xsl:value-of select="data [@alias = 'VsebinaPodstraniImage']" disable-output-escaping="yes"/>
</xsl:for-each>
</xsl:if>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Well, to get the image src for a property, you should use this:
Where you should replace "<<<YOUR_IMAGE_PICKER_PROPERTY_ALIAS>>>" with something like "data [@alias = 'imageAlias']" (NaslovPodstraniImage)
If you have a simple upload datatype this should work.
<img src="{$currentPage/data[@alias='imagePodstrani']}" />I think the problem with your code is that you are using copy-of instead of value-of.
@Dimitris
I really prefer the media section (/advanced media picker) for every type of media upload...
You never know if you're going to use it more than once and you've got all media managable in the same place ;-)
THX for all replies. Here's the code so far:
<xsl:stylesheet
version="1.0"
<div>
</xsl:attribute>
<div class="title">
<div class="icon">
<xsl:if test="$currentPage/ancestor-or-self::node[@level=1]/descendant::node[@level=3]/data [@alias='ImagePodstrani'] != ''">
<img alt="">
<xsl:value-of select="umbraco.library:GetMedia($currentPage/ancestor-or-self::node[@level=1]/descendant::node[@level=3]/data [@alias='ImagePodstrani'], 'false')/data [@alias = 'umbracoFile']" />
</xsl:attribute>
</img>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Here's the XSLT:
<xsl:stylesheet
version="1.0"
<div>
</xsl:attribute>
<div class="title">
<div class="icon">
<img alt="">
</xsl:attribute>
</img>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Somehow I must tell XSLT which image comes with certain subpage! How?
And if I delete the image in first subpage in a Content section, I get an XSLT reading error. Any ideas? THX
this blog post might help you: http://blog.leekelleher.com/2009/11/30/how-to-use-umbraco-library-getmedia-in-xslt/
if you want to select more than one image you'll have to use an ultimate picker:
the ultimate picker just returns you id's which you then have to use
umbraco.library:GetXmlNodeById(yourId)
here's some basic xslt to do that:
Hope that helps!
