So.. because all the nodes in our Umbraco install just disappeared without any reason we had to put a entirly new install, luckily we're still at the start fase. Now we decided to upgrade and put v4.5 and I just discovered the "Link to document" doesnt work like it used to?
I made a Website document type and a template for it: simple stuff. So I make the node in the content section and ofcourse his childnodes. Now I used to go to the properties of the site and then change "Link to document" to a subnode(Home). Now I see a template name(.aspx)?
So how do I choose a childnode as entry in v4.5.0?
No we cant since you are the only one who editted it. When i would say " this is a custom property that uses umbracoRedirect" you can use this posting as solved :)
Umbraco 4.5 - "Link to document" static?
Nevermind, I found out this is a custom property that uses umbracoRedirect.
Can someone mark this topic as solved? Im getting cute emails asking me about it.
Hell, if that makes the mails stop sure :P
