  • Nik Wahlberg 639 posts 1237 karma points MVP
    Jul 26, 2010 @ 14:42
    Nik Wahlberg
    Periodic Error
    Hi all,
    I keep seeing this in one of our installations from time to time. It's fairly rare, but so far I have not been able to narrow down what this is all about. Recycling the app pool usually does the trick, but I wanted to see if any of your have seen this as well.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
    Source Error:
    Stack Trace:
       umbraco.BusinessLogic.Utils.TypeFinder.FindClassesOfType(Boolean useSeperateAppDomain) +23
       umbraco.BusinessLogic.Actions.Action.RegisterIActions() +78
       umbraco.BusinessLogic.Actions.Action..cctor() +126
    [TypeInitializationException: The type initializer for 'umbraco.BusinessLogic.Actions.Action' threw an exception.]
       umbraco.cms.presentation._umbraco.RenderActionJS() +54
       umbraco.cms.presentation._umbraco.Page_Load(Object sender, EventArgs e) +1058
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +15
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +33
       System.Web.UI.Control.OnLoad(EventArgs e) +99
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +12
       System.Web.UI.Control.LoadRecursive() +47
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1436
    Thanks!
    Nik
    Jul 26, 2010 @ 14:44
    Nik Wahlberg
    Oh, sorry...this is 4.0.2.1.
    Jul 26, 2010 @ 16:49
    Ismail Mayat
    Nik,
    Is the website in its own app pool? You may also want to check if any action handlers are running and also if there are any custom datatypes possibly one of those is causing the problem?
    Regards
    Ismail
    Jul 26, 2010 @ 16:54
    Nik Wahlberg
    Thanks Ismail, I will take a peek at the Custom Data Types. To clarify this happens immediately after logging in.
    Cheers!
