  • Kim Kisbye 2 posts 22 karma points
    Jul 28, 2010 @ 10:01
    Kim Kisbye
    How to add a pre-defined headline in emails
    From our website, I want visitors to be able to click "send email" and an email with a pre-defined (by me) headline/topic is in the email. Is that possible? Anyone knows?
  • atze187 160 posts 215 karma points
    Jul 28, 2010 @ 10:54
    atze187
    You can achieve this by using .NET as described over at http://www.developer.com/net/asp/article.php/3096831/Using-ASPNET-To-Send-Email.htm
    To integrate that with umbraco (so you can set the topic in umbraco) you need to put that code into a user control that you can include in your templates.
    Jul 28, 2010 @ 11:05
    Kim Kisbye
    thanks, we will try that
