Will switching "useDirectoryUrls" to TRUE break incoming links?
Hi all,
So, I have been thinking that I'd like to switch the webconfig setting "useDirectoryUrls" to true for my site, to remove those pesky ".aspx" extensions, but I am concerned about all the external links coming into my site from different locations...
Will all those links now result in a 404 error?
Or will umbraco automatically chop off the ".aspx" and thus properly redirect them?
Or do I need to add some custom "urlrewriting" code to make this happen?
I'd just like to get an idea about what I'm in for if I make the change.
Your URLs will continue to work with the .aspx extention, so you won't get any broken links, but you may want to think about implementing a UrlRewrite rule to do a 301 redirect to the extentionless url, so that search engines don't see it as duplicate content.
(Or do not use the named reference ?<url> and use $2 here.)
So basically take everything that starts at the root of the website with a '/', ends in '.aspx' and doesn't start after the slash with 'umbraco/' or 'data/' etc. Obviously you can get more specific but that should do the trick.
Thanks to everyone for your replies. It looks like Sascha's is the closest to what I need, but when I used it with your named reference, there was an error message:
Parser Error Message: '<', hexadecimal value 0x3C, is an invalid attribute character. Line 40, position 90.
Which seems to do the redirecting properly now. (Yay!)
Now what I'd like to know is how can I verify that this is sending the proper "Permanent Redirect" message to Google? In another threa someone mentioned using Firebug to check, but I can't see where that information would be displayed.
The easiest way to test this has always been Fiddler for me, it has a huge amount of information and it can look a bit daunting at first, but it's such a great and powerful tool.
As sebastiaan says, Fiddler is a good free option, or if you don't mind a small charge you could also try Charles. Both pretty much do the same though.
This is exactly what I have been looking for - found it at last! Thank you Matt - and Heather for the wiki entry. When I initially tried this I had redirect set to "domain", which stopped this working, took me a while to spot the difference... doh
Hi all,
Thanks!
Heather
Hi Heather,
Matt
Thanks, Matt, for your quick response and your suggestion for the redirect code.
A search in the forum turned up
http://our.umbraco.org/forum/using/ui-questions/5255-301-redirect-options
which might help me figure that out.
Have a great day!
Heather
Hmm... This is proving more challenging than I expected...
My RegEx skills are not the best, and I am wondering how I can make this work for all my current pages without hosing the whole site...
My first attempt is this:
"\/*()\.aspx" matches all the pages in the site, though, including "/umbraco/" and other "reserved" dirs.
Does anyone know how to write the regex properly?
Thanks!
Heather
I think it would be something like this:
Hi Heather,
I reckon something like this should do the trick
Matt
Hi Heather,
that's indeed a bit tricky, I came up with the following regex:
And then
destinationUrl="${url}"(Or do not use the named reference ?<url> and use $2 here.)
Hope it works,
Sascha
So, I made some changes... and have this:
Does anyone know how I can test this?
~Heather
Hey Heather,
Matt
I think you can also check this with Firebug, in the .Net tab: all connections made are listed and the status as well.
+1 for Fiddler though as well, awesome tool. :)
Thanks everyone!
I found the "status" under the .Net tab in Firebug as Sascha suggested (had to click "All") and it said "301 Moved Permanently"
Success!
~Heather
I added a wiki page with this for anyone who might want to do the same thing:
http://our.umbraco.org/wiki/how-tos/how-to-switch-your-site-to-usedirectoryurls=true-when-it-was-previously-=false
~Heather
Awesome,
Great work.
Matt
Thanks again!
Dan
Always glad to help, Dan - and welcome to the community!
~Heather
