When I try to put more than one multi picker tree in a document i get an error saying that i have controls with duplicate ID's.
Anyone know if there is a fix planned to support multiple tree pickers controls in a single document?
Tree picker source here:
http://ucomponents.codeplex.com/
Si
I committed a patch for this issue, take a look here: http://ucomponents.codeplex.com/SourceControl/PatchList.aspx
It's the first one (by kipusoep). It's also assigned to a work item.
Good job kipu, i actually came back to this post to update it with the location of this patch since i just found it and tested that it worked!
Thanks!
No problem! ;-)
More than one Multi-Node Tree Picker v4.5 in a document type
Si
Thanks!
Si
No problem! ;-)
