  • chris 69 posts 92 karma points
    Jul 29, 2010 @ 17:52
    chris
    Feed Cache 1.1
    I'm using Feed Cache 1.1, and I have the umbraco folder set for SSL. I don't have a cert since this is a test server. Feed Cache is in the umbracoSetting config file under schedule tasks per instruction. The scheduler doesn't seem to run this, probably because of the SSL. Is there a work around?
    Mar 30, 2021 @ 19:28
    Alex Skrypnyk
    Hi Chris,
    If your application is accessible only via https - no way.
    Alex
    Mar 30, 2021 @ 19:37
    chris
    Alex, Interesting that I got someone to reply, from a question posted 11 years ago; usually nobody replies. We've moved on to Drupal a few years ago. Thanks!
    Mar 30, 2021 @ 19:39
    Alex Skrypnyk
    Ah, sorry, I didn't see that it's so old topic, strange that it was showing in the feed on the Forum section.
