  • syn-rg 282 posts 425 karma points
    Aug 06, 2010 @ 03:11
    syn-rg
    Content node context menu
    How can I add the "Notifications" option to the top node in the Content section?
    Only nodes under the Content node have the "Notifications" option.
  • Aaron Powell 1708 posts 3046 karma points c-trib
    Aug 06, 2010 @ 04:19
    Aaron Powell
    I don't believe that you can and have it run the way you'd be expecting. Because the root node doesn't have an actual ID I don't that it'd be picked up properly and have notifications filtered all the way down.
    You can try it out, and it should be possible to add one the same as adding any other context menu item (using the BaseContentTree.BeforeNodeRender event). Here's some sample code on how to do it: http://our.umbraco.org/forum/developers/extending-umbraco/5878-VB-code-for-adding-context-menu
