I have also experienced this in 4.5.1 using Chrome, IE8, Safari and Firefox. I was able to sort them, but upon Save and/or Publish my changes would revert back to what they were.
I tested again today before posting, and I am now getting an error:
Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] umbraco.editorControls.macrocontainer.Editor.Save() +1018 umbraco.controls.ContentControl.saveClick(Object Sender, ImageClickEventArgs e) +184 umbraco.controls.ContentControl.savePublish(Object Sender, ImageClickEventArgs e) +23 System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e) +133 System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument) +164 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3690
I am also getting thr problem whereby the macros revert to their original order when publishing ... but I haven't yet experienced the error. I see the codeplex issue has been closed but can't see any resolution ... does anyone know any more about this?
Macro Container not allowing ordering macros
On some nodes, not all, I am unable to reorder macros within the Macro Container control.
Has anyone experienced this and is there a fix?
Stack Trace:
We do also get this exception on some nodes
Umbraco version v 4.5.2 (Assembly version: 1.0.3891.20719)
I have created a issue on codeplex
http://umbraco.codeplex.com/workitem/29799
Comment author was deleted
Did you also remove a macro ? Or just a sort?
