Insert/Edit link Media content is "grayed" (disabled)
Hello.
I'm tried both Umbraco 4.5.0 and 4.5.1 installations with Runaway module. But when I'm trying to add link to my media files using RTE the tree with Folder and Files is disabled. Any ideas why it's happening?
This somehow seems to have something to do with the length or size of the upload... I've FTP-ed the 16 MB PDF to the server and initiated the upload from there. Everything worked smoothly then...
Bump.. I am experiencing this behaviour. Picking nodes actually works although if you try to pick a folder, it causes a 404 error in the Insert Link popup.
Hello.
Exactely the same problem on my new fresh 4.5.1 install.
Anyone has already encounter that kind of behavior?
Kind Regards
David
Same thing here... Does anyone have a solution?
Thanks!
Odd...on mine they show grayed out / disabled, but I am able to click and select images with no problem in both FF and IE. Running 4.5.1
Anything new on this topic?
We are having this problem after upgrading from a V3 site to 4.7
I'm getting this on 4.7 too. I'm using a virtual directory for the media section.
Is this permissions related?
Still noticing this in 4.7.1.1. Anyone know if it's been fixed in 4.7.2?
Its just a simple CSS bug, I added the following to \umbraco_client\Tree\Themes\umbraco\style.css
.tree.tree-umbraco li.leaf a
color: #2F2F2F;
.tree.tree-umbraco li.dim.leaf a
color: #C0C0C0;
At line 179, just after ".tree.tree-umbraco li.dim a", this seemed to work for me.
