  • Pavel 1 post 22 karma points
    Aug 13, 2010 @ 18:29
    Pavel
    Insert/Edit link Media content is "grayed" (disabled)
    Hello.
    I'm tried both Umbraco 4.5.0 and 4.5.1 installations with Runaway module. But when I'm trying to add link to my media files using RTE the tree with Folder and Files is disabled. Any ideas why it's happening?
  • David Dupont 61 posts 115 karma points
    Aug 20, 2010 @ 10:46
    David Dupont
    Exactely the same problem on my new fresh 4.5.1 install.
    Anyone has already encounter that kind of behavior?
    Kind Regards
    David
  • Robert Hessels 6 posts 26 karma points
    Aug 20, 2010 @ 18:58
    Robert Hessels
    Same thing here... Does anyone have a solution?
    Thanks!
    Aug 20, 2010 @ 19:32
    Tom Fulton
    Odd...on mine they show grayed out / disabled, but I am able to click and select images with no problem in both FF and IE.  Running 4.5.1
    Aug 22, 2010 @ 20:11
    Robert Hessels
    This somehow seems to have something to do with the length or size of the upload... I've FTP-ed the 16 MB PDF to the server and initiated the upload from there. Everything worked smoothly then...
  • Niklas Jalmerud 26 posts 62 karma points
    Apr 26, 2011 @ 10:08
    Niklas Jalmerud
    Anything new on this topic?
  • Dan Evans 631 posts 1018 karma points
    Aug 11, 2011 @ 18:13
    Dan Evans
    We are having this problem after upgrading from a V3 site to 4.7
  • Ben Edwards 11 posts 32 karma points
    Aug 26, 2011 @ 11:14
    Ben Edwards
    I'm getting this on 4.7 too. I'm using a virtual directory for the media section.
    Is this permissions related?
  • Barry Fogarty 493 posts 1129 karma points
    Oct 05, 2011 @ 23:33
    Barry Fogarty
    Bump.. I am experiencing this behaviour.  Picking nodes actually works although if you try to pick a folder, it causes a 404 error in the Insert Link popup.
  • Douglas Ludlow 210 posts 366 karma points
    Jun 01, 2012 @ 19:33
    Douglas Ludlow
    Still noticing this in 4.7.1.1. Anyone know if it's been fixed in 4.7.2?
  • Alan Donnelly 2 posts 55 karma points
    Jul 25, 2012 @ 11:37
    Alan Donnelly
    Its just a simple CSS bug, I added the following to \umbraco_client\Tree\Themes\umbraco\style.css
    .tree.tree-umbraco li.leaf a
        color: #2F2F2F;
    .tree.tree-umbraco li.dim.leaf a
        color: #C0C0C0;
    At line 179, just after ".tree.tree-umbraco li.dim a", this seemed to work for me.
