  • SinkyPars 132 posts 175 karma points
    Aug 16, 2010 @ 15:40
    SinkyPars
    Changing a logo depending on criteria
    Hi guys,
    I would like to change the logo of a document depending on what the have selected in a drop down in the document type - is this possible?
    Scott
  • Eric Boen 40 posts 64 karma points
    Aug 16, 2010 @ 16:12
    Eric Boen
    Do you mean user selected (on a web page) or adminstrator selected (in the administration section)?
    Eric
    Aug 16, 2010 @ 17:04
    SinkyPars
    Hi Eric,
    For example - When a user is adding a new page and they select from a drop down to pin the page to a certain menu - how could I change the logo in the content tree depending on this drop down value?
    Scott
  • saivignesh 2 posts 72 karma points
    Aug 17, 2015 @ 11:14
    saivignesh
    Hi sinky, Did you get an solution for this. If so please tell the solution.
    thanks.
  • Samira 113 posts 452 karma points
    Aug 17, 2015 @ 12:33
    Samira
    2
    Hi SinkyPars,
    If u want to change logo of subitem in content tree
    1. Goto to setting in admin backoffice
    2. Open document type and click any document u mention there.
    3. In info section Choose icon for logo
    Grazitti
  • Tom Van Rompaey 38 posts 136 karma points
    Aug 17, 2015 @ 14:02
    Tom Van Rompaey
    I haven't used this package myself yet but maybe this is what you are looking for: https://our.umbraco.org/projects/backoffice-extensions/stately/
