Using 4.5.1. I have created a new css called it Editor and assigned it for rich text edit field. In settings under that css i have created 2 child elements h1 and h2 and for those definitions put some style information in basically font size change. When i go and view content in editor as expected i can see the styles drop down with my h1 and h2, however the rich text edit field is all black in colour. The editor css is blank it has nothing in it so no idea why its picking up black colour
Is the styles in the elements you add not just for the dropdown menu? I think if you put those styles in the main Editor.css as well it should work (although I could be wrong).
Did you find a solution for this? I have a similar problem where the TinyMce rich text editor picks up the background image that I specified in the body tag in my css file. Maybe your body tag has a black background? If so, change that.
In my case, my body tag in my css looked like this:
body {background: url(img/darkBackground.png) repeat-x;}
The TinyMce rich text editor picked up that dark background, and cached it somewhere so that even after I deleted the background attribute in my css file, the editor still showed it.
I finally had to actually change the image to a different .png file with a light color. Then, oddly, Umbraco logged me off and forced me to log on again, and then I saw the light background in the editor. Very strange.
Sorry for hijacking this thread. Here's the link to my original question which is similar to Ismail's question. Doug Robar posted a solution which essentially uses a separate set of styles for the mce editor so that you can give the editor its own background color.
Editor css changing colour of rich text field
Guys,
Any ideas?
Regards
Ismail
Hiya,
Hi Ismail,
body {background: url(img/darkBackground.png) repeat-x;}The TinyMce rich text editor picked up that dark background, and cached it somewhere so that even after I deleted the background attribute in my css file, the editor still showed it.
http://our.umbraco.org/forum/using/ui-questions/11943-Help-with-CSS-in-TinyMCE-editor
--steve
