  • Mike Chambers 636 posts 1253 karma points c-trib
    Aug 17, 2010 @ 14:35
    Mike Chambers
    Trying to add the "ToggleVisualAid" functionlaity to TinyMCE.. without luck
    I've updated the TinyMCConfig.config with
        <pre><command>
          <umbracoAlias>visualaid</umbracoAlias>
          <icon>images/editor/visualaid.gif</icon>
          <tinyMceCommand value="" userInterface="false" frontendCommand="visualaid">visualaid</tinyMceCommand>
          <priority>81</priority>
        </command></pre>
    Which results in the developer/datatypes/richtexteditor having the checkbox/icon for visualaid, and I've checked that and saved. However, unlike other items I've added like xhtmlxtras (abbr/acronym) this doesn't result in the icon showing in the tinymce toolbar
    Doing a google search got me to the source for TinyMCE.cs...
    This seems to have visualaid as always hardcoded to be disabled?
    private string _disableButtons = "help,visualaid,";
    Is this a correct interpretation? and if so is there a reason why umbraco can never have togglevisualaid support?
    Mike
