I'm trying to customize the Blog 4 Umbraco archive post list, which appears on the right hand side of the blog posts list. On install the archive list show other post as a UL and LI list indented.
I'm trying to configure this as:
Month Year
Post Title
Post Date
Blog 4 Umbraco stores blog posts in a Blog document type, then year, month and day document types. I'm struggling to think how to get the XSLT to parse the folders by month, this is what I have so far:
Blog 4 Umbraco - Customizing Archive Post List
Hi all,
Month Year
Post Title
Post Date
<xsl:for-each select="$currentPage/ancestor-or-self::node [@nodeTypeAlias = 'Blog']/node [@nodeTypeAlias = 'DateFolder']"> <xsl:sort select="@nodeName" data-type="number" order="descending" /> <xsl:for-each select="./node [@nodeTypeAlias = 'DateFolder']"> <xsl:sort select="@nodeName" data-type="number" order="descending" /> <!--<li class="month">--> <xsl:variable name="monthname" select="umbraco.library:FormatDateTime(concat(./../@nodeName,'-',@nodeName,'-11T10:24:46'),'MMMM yyyy')" /> <a class="archive-date-link" href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="$monthname"/> </a> <span> <br /> <div style="color:#fff;"> <a style="color:#fff;text-decoration:none;"> <xsl:attribute name="href"> <xsl:value-of select="umbraco.library:NiceUrl($currentPage/ancestor-or-self::node/node/node/node/node/@id)" /> </xsl:attribute> <xsl:value-of select="$currentPage/ancestor-or-self::node/node/node/node/node/@nodeName" /> </a> </div> <div> </div> <div style="color:#999;"> <xsl:value-of select="umbraco.library:FormatDateTime($currentPage/node/node/node/node/@createDate, 'dd/MM/yyy')"/> </div> <!-- (<xsl:value-of select="count(.//node [@nodeTypeAlias = 'BlogPost'])"/>) --> </span> <div class="blog-separator"><!-- --></div> <!--</li>--> </xsl:for-each> </xsl:for-each>Any help you could give would be appreciated.
