  • Glenn Turner 2 posts 22 karma points
    Aug 23, 2010 @ 16:07
    Glenn Turner
    catch 404
    Hello
    In my website there are two languages: dutch and french. For each languagesection I want a different 404 error page.
    I've changed the umbracoSettings.config like this:
            <error404>
                <errorPage culture="default">1245</errorPage>
                <!--<errorPage culture="nl-NL">1245</errorPage>-->
                <errorPage Culture="nl-BE">1245</errorPage>
                <errorPage Culture="nl-NL">1245</errorPage>
                <errorPage Culture="fr-BE">1377</errorPage>
            </error404>
    But when I create a 404 error, only the default is used. If I delete the default value, then I get the ugly error from umbraco.
    Any idea's?
    Thank you!
  • Donald St. Martin 83 posts 128 karma points
    Aug 23, 2010 @ 16:27
    Donald St. Martin
    Glenn,
    Check out the second to last post on this page: http://our.umbraco.org/forum/developers/extending-umbraco/4216-404-handler---Doesn%27t-work?p=1
    Hope this gets you pointed in the right direction.
    Donald
    Aug 23, 2010 @ 16:33
    Glenn Turner
    Thank you for the reply, but I'm not using windows 2008 server with IIS7. I'm hosting on a win2003...
