  • Mike 80 posts 101 karma points
    Aug 25, 2010 @ 09:42
    Mike
    Image Cropper, Doctypes and 4.5
    I couldn't find this so let's post...
    I see the imagecropper is default in 4.5, but I was wondering, does this one also have the scalable viewport implemented so when cropping a large image it is resized to the users screen?
    Does the export/import of doctypes with master/child work in this release? Previously, when importing a nested doctype, the children would be imported as single doctypes.
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Aug 25, 2010 @ 12:36
    Tim
    Hi Mike,
    I'm not sure on the image cropper resizing. Its just this pacakage: http://our.umbraco.org/projects/backoffice-extensions/image-cropper so it might be worth checking the forum in there to see if it does that.
    As for the export, I believe it still works the same as before (sadly). You could maybe create a package and add the docType and its parent doctypes to it and try importing that?
    Sep 03, 2010 @ 12:30
    Mike
    Finally found the time to install a 4.5 release today. Creating a package with doctypes with master/childs and re-installing works good.
    Image Cropper doesn't have the viewport thingy installed. Too bad... i'll have to check the forums for this.
