  • Kate 267 posts 610 karma points
    Aug 26, 2010 @ 15:06
    Kate
    Insert Flash from page
    Hello
    I am new to umbraco so pleas be patient.
    What I would like to make is that the end-user, from a page, can upload a swf file.
    For example, if I, on my home page, has an area where there must be a video which the user must be able to change them self.
    So there must be a tab on the page that contains the ability to choose a swf file from the Media
    I know how I have created a tab through a document type, but I am unsure what to write in fields: Name, Alias and Type
    I've looked at some examples here in the forum, but without success.
    What I need is a thorough description of how to do it.
    Hope someone can help
    Aug 26, 2010 @ 16:10
    Ismail Mayat
    Kate,
    You need to create a field of type media picker you can give it whatever alias this will allow user to pick media item form the media section.
    Regards
    Isamil
  • sun 403 posts 395 karma points
    Aug 26, 2010 @ 16:13
    sun
    Maybe you can see RTE datatype to set.
    Sep 01, 2010 @ 14:17
    Kate
    okay, I dont quite understand what you mean.
    I will try to describe my problem a little closer.
    I know I wrote that I would insert a flash, but for convenience's sake let's just insert an image.
    I have an GetImageURL.xslt that looks like this:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
      <xsl:value-of select="/macro/imageID/*/umbracoFile"/>
    </xsl:template>
    </xsl:stylesheet>
    Macro have I put into my template:
    <span class="spot spot1" style="background:url(<umbraco:Macro  Alias="GetImageURL" runat="server"></umbraco:Macro>) no-repeat;" onclick="showText(this.id)" id="et">
    (I know it is not the right way to put the macro in, but I do not know how else I should do it.)
    When I insert the macro, I am asked to choose an image (and the height and width, I think). Why is that?
    And how do I get it to work with my front page where the user must insert the image / flash file?
    Hope it gives a better picture of where I am in my project Umbraco :-)
