  • Amigo 245 posts 600 karma points
    Aug 27, 2010 @ 10:37
    Amigo
    show hide content
    I need to create af functionality so i can show/hide content on a subpage.
    Something like create diffrent types of content on a page, but with a show/hide check box related to each content area.
    How can i do that?
    Aug 27, 2010 @ 23:22
    Hi Thomas
    If I understand your question correctly you need to add some JavaScript to toggle, what content should be shown/hidden.
    If you are using Jquery on your site maybe you should include the jquery ui script, which makes it easy to make tabs for instance: http://jqueryui.com/demos/tabs/
    You can also simply write some code that allows you to toggle between content - see the Jquery documentation for reference: http://api.jquery.com/toggle/
    There are probably also loads of examples on how to do this on google :-)
